I need a PS Pulley!
christoc Offline
Anyone have a suggestion on where to get a new pulley for my new power steering pump?
The old pulley had to be cut off of the bad pump [Image: frown.gif] it was a messy job.
I tried a ford dealer, they said there was one dealer in the country who had one and it would be $70 plus freight, which I can do, just want to make sure if that's my only option or not.. Anyone know what else might work?
http://www.solo2.org
http://www.chrishammond.com
Chuck W Offline
How did you wind up having to CUT a p/s pulley off?
Anyway, what year car might help.....
83 TC Clone, 87 Ranger 2.3T, 84 XR7, 80 XR7, 86 XR4 AND 88 Scorpio
christoc Offline
Whoops sorry [Image: smile.gif]
88 t-coupe.
I used a tool to remove the pulley, yet the pulley would not come off the the old pump. It managed to deform the pulley so badly that it would no longer be usable. To get the pulley off the pump my buddy ended up removing the bracket that the pump mounts to from the car and using a plasma cutter on the pulley.
It was a PITA trust me [Image: smile.gif]
Ryan H Offline
Thats the first I've ever heard of that happening. Either way, I would think a JY pulley from a 3.8 might work, but I'm not sure on that. Also, other JY pumps could be the same, might want to do some searching on that to see if the N/A Fox bodied stangs have the same pump, if so then you're in luck [Image: smile.gif]
Ryan Harris
1988 TC, 5 speed, all options including sunroof Smile
1987 3.8L V6, C4, 160K miles, no options (winter car, when it works)
RIP 1987 TC, "Built" A4LD, 119K miles, all options except sunroof Sad
My Audio Mixes
Chuck W Offline
SOunds like you were trying to use a big 2 or 3 finger gear puller instead of a P/S pulley puller...Thte p/s ones clamp around that grooved boss in the center of the pulley..thus you don't deform the pulley trying to remove it..
christoc Offline
[Image: frown.gif] that would be correct.... I didn't realize there was a difference
Hurff Offline
The irony here is that you might need that tool to press the pulley back on without banging up the pump....
However that said I have done it without. Autozone rents the tool for a deposit.
I second (or third) the JY pulley, should be one out there in a u-pull.
However if none are available www.junkyarddog.com request the part and emails will flood your inbox. My guess, $5.00 - $10.00
1987 TC - RIP
christoc Offline
Well, I'll take the puller I got from autozone back and get the proper one for install!
BJL Offline
Moderator
any EFI 2.3l with serpentien belt wil work
Brian J Larkin
1988 Non-Turbo Turbo Coupe
new paint job as of 12/8
med gray met. raven/gray interior, fully loaded minus leather and sunroof!
converted to N/A 2.3l by previuos owner, but its a nice driver with working A/C!
sequentail turn signals, 3g alt,afpr, k&n, 2 1/2in cold air intake.
custom 2in dual exhuast with SN95 SS tips. Tripcomputer, a/f and vac guages. color coded wheels
1988 Turbo Coupe 5spd
gillis boost valve, k&n cone,AFPR, 255lph, HP pump,3G 130amp alt, 3.73 gears,mild torquie cam, factory DP, 2003 mustang take off SS mufflers and custom BJL 2 1/4 tails.
(needs a front frame pull) DOH!!!!!
Brian Larkin
88TC 330,000 miles
Slightly Modified
2birdsinthefalls887 Offline
Just measure your old pulley diameter, and count the belt ribs on the pulley, the width of the pulley. I believe, I am sure the inside diameter of all the pulleys on a c-2 power steering pump are the same.
88 Turbo Coupe,loaded 104,000,
88 Turbo Coupe,Fully loaded,
