I need a part number!!
Noname
Guest
Damn well at work I asked my friend to check up on the ECT sensor and he says he can't find anything. He tried searchin for any sensor or relay that had to do with Coolant or Fans, and found nothing, what the hell?
I heard from someone that the only thing that has to do with the fan is the ECT and the computer. Shouldn't there be a relay or switch for the fans though? Are you sure it is the only thing that tells the fans to come on?
1988 TurboCoupe - 5 Speed
6" K&N / Cold Air Intake, Gillis Valve @ 17 psi, Centerforce Dual Friction Clutch, Pro 5.0 Shifter, Autometer Boost/Vac & Air/Fuel Gauges
Noname
Guest
nevermind, I should read things before I post. I understand what I need to test now, the only thing I need to know is, what is the KOEO EEC diagnostic test? I know that KOEO means key on engine off, but what else do I have to do?
