I'm sooo lucky - (injectors)
Walsted Offline
I noticed a faint gas smell coming from the engine compartment and a liquid sheen on the top of the #3 injector, so I decided to change the seals and clean the areas where they meet the intake manifold and fuel rail.
Pulled #3, and it was real dirty. A bit of dirt was caked on the fuel rail seal, and something resembling a silver colored paste was present in the gap near the seals. The intake on #3 had a lot of dirt caked in it, which I gently removed with carb cleaner and paper towels. Cleaned off the injector, changed the seals, and reinstalled.
Pulled #4, and noticed that there was NO SEAL on the fuel rail side. I checked to see if I had dropped the seal, but it was nowhere to be found, and I don't know how it would get off on its own, anyway. Guess that is where the smell was coming from. Installed the two new seals, and cleaned the injector, and it was ready to go.
Numbers 1 and 2 looked okay. Changed those seals, anyway, and reinstalled.
Reinstalled everything, and no more smell of fuel.
Since this was the first time I pulled the fuel rail, the scary/lucky part is that I have been driving this car with the seal missing on the fuel rail side of #4 since January 2001. That is approximately 55,000 miles, including three trips from D/FW to California and back. I had noticed a small bit of liquid pooling on the intake manifold, but I always attributed the liquid to a leaky valve cover gasket, since the liquid looked to be the same color as old oil.
Total time for the seal swap was about an hour in light rain with plenty of tools. If anyone else has liquid pooling on their intake manifold, I highly recommend checking the seals if they haven't already done so.
Hope this helps someone, and prevents what could have happened to me from happening to anyone else.
Mike Walsted - NATO member
TurboCoupe50 Offline
You sure the seal wasn't stuck up in the fuel rail??? They often pull off the injector and stick in the rail. Maybe it wasn't there, but you'll never convence me of that. Without the "O" ring it would flood the engine compartment with fuel.
Three 1988 Turbo Coupes .....
yea one of em has a 5.0 And runs 13.1s......
uhhh make that [email protected] with a 90hp shot of nitrous.
1988 Turbo Coupe331 AOD
1972 Comet GT
I agree with Tom, with no O ring on there, you would have been dumping at least a quart a minute of gas out on the motor.
Glenn 88TC Offline
I agree with Tom also. You would definitely notice the leak if there wasn't an O ring on there.
NO TC and NO headaches.
Walsted Offline
It must have flown out when I was removing it, then. I was thinking that it might have stuck in the fuel rail, but it wasn't there when I looked. I guess it must have flown off and landed in the never never land of the frame and suspension, under the engine but not quite on the ground, the same place many of my nuts and bolts migrate to when I am doing other work. I did have the lower intake covered with a rag, so I am sure it didn't go that route.
I vote with Tom, Jeff and Glenn.
An Hour is pretty good. Did you pull the TB/Upper?
Walsted Offline
Yep, pulled the upper intake. I left the TB on the upper, though.
Still can't figure out where that seal went, though. When I pulled out the injector, it fought hard, and I didn't see the seal when it came out, even after checking the rail and vicinity.
[This message has been edited by Walsted (edited 07-29-2004).]
