i don't know?
Harvs Offline
well, i drove my car down the street (you cant really go that fast or boost enough to see), but its stumbling, it struggles to idle if you rev it. It bogs then goes back up to 1500 then back down to almost the point of stalling, then it will settle back to 1000.
Sandlewood beige 88 coupe 93k/ super 60 T3 at 24 pounds/ ATR 3" no cat or tail pipe/ 255lph high pressure pump/ Kirban AFPR at 42/ Spec stg3/ GN FMIC/ Blitz BOV/ 14* timing/ disconected KS/ Tri-ax short throw/ Autometer boost,vac and air to fuel/ 140 spedo/ Ford motorsports 5300-c springs/ tubular rear upper cntrl arms.
fordprefect Offline
Sounds like what mine is doing. Are you getting a code 42 (always rich)? I am right now trying to track it down.
Steve
'88 TC 5 speed 161k White/Red w/leather(air freshener:-)K&N cone,
'74 VW Bug Black/Black Heat in the summer & AC in Winter!
"I Love Deadlines, I Love the Whooshing Sound They Make As They Pass By" DNA
SteveX82 Offline
I bet it has nothing to do with fuel pressure / ignition or cam timing / intake leak like just about EVERY other post made about stumbling problems.
Maybe it's just drunk [Image: smile.gif]
Estoril blue 1987 TC 5spd, 146k miles, a237, Bailey BOV, spec stg3 clutch, spearco FMIC, t3/t4 50 trim / stage III .63, 3" exhaust, eec-tuner, lm1 wb, 55pph injectors
Best 1/4 mile: 12.89 @ 106mph on 25psi, 1.78 60'
Was the engine throughly warmed up when all this happened???
Harvs Offline
I found the issue, my bov flange has a crack in it, ill just weld it back.
