Ashok
Mar 2007
Beaverton, OR
I searched this forum without success for any tips or articles on how to remove the 87-88 TC's master cylinder brake assembly from the firewall?
The four big bolts that attach the brake assembly to the firewall has hex nuts on the inside- under the dash behind the instrument panel and two upper nuts appear inaccessible. Wondering if any special tools, like curved wrench, is required to remove the brake assembly?
I would really appreciate the wisdom from someone who has removed & installed this brake assembly.
THANKS, TIA
--Ashok 87TC, OREGON
Ashok
Mar 2007
Beaverton, OR
Sorry, I initially posted this brake question in wrong area. I am new :-)
Now it is in the correct forum.
RK87TC
Nov 2004
Clearwater, FL, USA
For starters you almost have to take off the intake to get it out. A set of the flex-head gearwrenches is just the ticket for the 4 nuts inside on the firewall.
I tried it once without taking off the intake and wound up using a sawzall...lol....then I put plain vacumm boost brake package in so I'd never have to mess with that again. Now I can service the system if need be.
Ralph
evintho
Dec 2003
Santa Rosa, CA.
IIRC, when I stripped my '88 parts car I dropped the steering column and was able to access those bolts with a 24" extension and a wobble socket. But I think for one of them I had to lay on my back with an open end wrench and turn it 1/8 turn at a time!
Proverbs 3:5
Check out Thunderstang!
Ashok
Mar 2007
Beaverton, OR
Ralph, good suggestion about FLEX-HEAD GEAR WRENCH. I don't own this tool but will be out looking to buy a set. It may do the job?. I assume intake manifold needs to be removed just to allow some clearance for the MC Assy to be pulled out. Thanks.
Ashok
Mar 2007
Beaverton, OR
John, thanks for tip on another special tool: WOBBLE SOCKET & EXTENSION. I may need to get this if the recommended flexhead gear wrench does not work for me.
You say to access one of the 4 bolts of the MC Assy behind the firewall, you had to "lay on your back with an open end wrench and turn it 1/8 turn at a time". Well, to do this, did you have to remove the driver's seat?
My MAJOR goal here is to "disrupt" fewest unaffected parts as possible in order to remove & replace the MC brake assembly.
RK87TC
Nov 2004
Clearwater, FL, USA
that 1/8 of a turn bolt/nut is just exactly what the flex/gearwrench is for and yes, taking out the manifold just makes it easier to get the d@#$% thing out of there. And no you don't have to take out the front seat. With the gear wrenches you don't even have to drop down the steering column if I remember right. They'll allow you easy removal of all the nuts.
Ralph
zerobudgitbird
Sep 2005
victoria bc
an air ratchet made unbolting it a 10 min job for me
1988 t/c,stone stock,230,000 mi and going strong
Ashok
Mar 2007
Beaverton, OR
Aren't the air ratched bigger and bulkier than gear wrench? I wonder how you managed to squeeze the air ratched head onto the upper two nuts which are partially blocked by the steering rod.
