RDOG
Jun 2001
Ontario. California U.S.A.
Hey guys, can this be buffed out? If nit whats the next best choice besides having to paint it. Painting it is my last alternative.
http://i158.photobucket.com/albums/t97/b...intpsd.jpg
If you look at the trunk it is faded really bad and looks like peeling clear.
Quote:If nit whats the next best choice besides having to paint it
Wear Extremely dark sun glasses
Sorry ,but my guess is a repaint is the only "good" fix
RC Martin
Mar 2006
Colorado
In theory if you got all of the clear off you could buff and polish it up... I don't know if it's all the same paint under the clear?
One of the reasons my TC looks so nice is because I don't have a clearcoat to be peeling off. It also needs to be waxed once or twice a year to avoid the faded tomato color lol.
TCLover82
May 2012
Charlotte, NC
I can't tell much from that pic, but you might be able to bring it back with a good buff/polish/wax. I would be careful though, the stock color coat that is left after the clear peels off on the 86-88 cars is extremely thin, and it will be really easy to burn through it. I tried it on my '88, and ended up burning through on the roof. I gave up trying to bring back teh stock paint after that and just conceded that it needed a re-paint. Which it will be getting soon.
'88 Thunderbird Turbo Coupe - 120K miles, 99% Rust-Free, 351W/AODE Swap coming soon!
Looks like the clear coat is peeling. I had several cars do this, the answer from the body shop is always "needs repainted". If its only on the trunk you got lucky, they can usually match the color and repaint the whole pannel and not have blend time in it.
Jack
FLSTCI71
Apr 2004
Rochester, MN
I agree with the others. There is no fix for that other than your last alternative. At least, none that I am aware of.
1987 Turbo Coupe - Son's car
1987 Super Coupe - Son's project car
1934 Ford - My project car
RDOG
Jun 2001
The body is super straight too. Ugh! What about vinyl? If I just do the top half, how cheap is that?
I was just quoted $600 to rhino it in flat black, but i hear it nmake the car interior hot and adds about 30 lbs.
Hard to tell but can you buff or cleaner wax it and either use wax to make it shine like ultra finish, or carnauba wax. Maybe also tape it up and buff and re clear coat it yourself? Do you have a spare fender or something to practice/test it?
-88 TC Black
-97 Pathfinder
RDOG
Jun 2001
I'm a oil and wrench kind of guy. Never been much into buffing and stuff. Guess its time to give it a shot. Keep your fingers crossed
Martin
Aug 2001
Agassiz, BC, Canada
If there is a section to try Rubbing Compound, I have had luck with that. Thurtle makes a good Rubbing compound. Basically a wax base with grit in it, but it does a good job of taking of a fine layer of dull clearcoat or paint. After you use the compound you have to wash and waxa lot more often.
Boost High, Fly Low
