How Valve springs are checked
I had to check the valve springs for a 4G63T
This is a simple process. But a specialized piece of equipment is needed.
I use a Rimac spring tester with a 300lbs scale.
The first thing to do is set the stop to the correct height.
The spec used is 66lbs @ 1.575
I find that a venier caliper is more accurate than the built in scale.
[Image: DSCF3967.jpg]
Place the spring to be tested in the spring tester
[Image: DSCF3966.jpg]
Compress the spring to the pre set height and read the pressure.
[Image: DSCF3968.jpg]
It is a quick and simple way to have your valve springs checked to make sure they are in good serviceable shape.
Low spring tensions can lead to a lazy rev of your engine and also valve float.
Most of the valve springs I tested I found to be well out of a usable spec.
Most springs I tested fell in the range of 40-55lbs @1.575
Most spring manufactures allow for 10% loss of spring pressure for spring break in.
Owns more Turbo FORDS than the law should allow....and still getting more
85 TC going under the knife
84 Turbo ranger --($800.00 ebay) Redneck work truck
