1987tc
Bicknell Indiana USA
What is the capacity of the 8.8 dif? I have the traction lok friction modifier additive but I am not completely sure how much it will hold. I know that you are supposed to use the plug on the dif as a gauge but would like to know how much from dry it takes to fill. This way I can use the plug for the final top off.
Wes
1987 TC:
Hurst compition plus shifter,K&N cone,rollor cam,custom single exhaust,Gillis valve,H&R springs,KYB shocks,struts and quads.
3.73 rear. lots more to come!
Linton Indiana
Ford spec book calls for 4 pints + 4 oz of friction modifier
manifolds, polished and cc'd chambers, RR, Crowler, ARP head studs, Walbro 190 pump and T-3 for starters. KB subs
and jack rails
1987tc
Thanks Pete,
That is exactly what I did! I am about half done with putting in the 3.73 rear end from my parts car. While I had it out of the car I cleaned it out and refilled it with the fresh oil and additive.
Everything looked to be in great shape too. I figured it was a good time to take a look.
1987 TC:
Linton Indiana
