How much boost do "normal" turbo cars have?
segfaultxr7 Offline
I was talking to some people online about turbo cars and mentioned the T-Bird makes 15-17 psi stock. They acted like I was insane! They were like "Are you SURE? That can't be stock. Did you disconnect the wastegate actuator? You're going to blow up that engine!" and so on.
So, what's a normal boost range for a typical turbocharged car? I know the Chryslers only made 7 or so, but I just figured that's because anything more would blow up their transmissions. [Image: wink.gif]
88 TC 5-speed
The non intercooled cars were I believe around 10 psi. Some may have gone 12, not sure. The intercooled cars were capable of 14-15 (5spd manual trans) but some only got that in 1st and 2nd (87, early 88s), 10 psi in 3,4 & 5, automatic 87-88 TCs were less.
segfaultxr7 Offline
I see.. My 88 (12/87 build) will read 15-16 or just a little over at its maximum. It is limited in 3rd thru 5th, but will hit full boost at 4400 rpm in any gear.
There was a T-Bird show on TV a few weeks ago, it showed a clip of an 88 Turbo Coupe commercial and you could clearly see the boost gauge go beyond 15psi and to the bottom of the red area! I know the boost gauge is inaccurate, but I still thought the latest TC's went beyond 15.
88 TC 5-speed
Mr. Sam Ford Offline
Most other turbo cars are restricted to 6-10 psi of boost. Volvos, Saabs, not sure about DSMs. Even the intercooled ones don't run much boost. I've gotten the same surprised reaction when I say I'm running 20 pounds of boost. Ford builds an engine capable of taking it, which says alot
'88 Thunderbird TC
ATR 3" cat back, Sac. Mustang 3" DP, Tiny Avenger boost controller, K&N cone in fenderwell, Walbro 255 lph fuel pump, Perf. Techniques T03/T04E turbo, KB Trac Kit, 4 cyl. Mustang springs
'86 Mustang GT
usual bolt on stuff
'88 Thunderbird TC A4LD
'88 Thunderbird TC, daily headache with a few mods, 14.65 and still not happy Smile
Ohio88TC Offline
I remember one of my teachers having a talon and it only got 9-12 and I have friends that have eclipses and other DSM cars which are intercooled and they run 9-12 even the ford probe gt turbo ran around there. Ford knew how to build one hell of an engine to run it from the factory at 15psi [Image: smile.gif] Thank god for 2.3L Turbo's and lets not forget Airresearch and Warner [Image: smile.gif]
Noname
Guest
Pete D hit the nail on the head. The '88 Automatic i had only went to 5-6psi when i got it and 10psi after i put in a bleed valve....it was very early in the model year i believe...the '88 5-speed i have now goes to 14-15psi 1-2 and 8-9psi 3-4-5 and its also fairly early.
zora_d_1991 Offline
I have the tv clip you are talking about on tape. the show was on the history channel. you can clearly see when you slow the tape down that the boost guage pegs right on 18 on the boost guage. its a pretty cool shot.
"thank you for flying red bird airlines....enjoy the flight."
Scott Evil Offline
It is probably apples to oranges, but my S4 puts out 14.7 psi of boost, stock. Each turbo has an intercooler which helps. They are also low pressure blowers so the 14.7 is net pressure from both.
1986 SVO 1D <19,000 miles
2001 Audi S4 Silver (the fastest color)
Smoked_Ham Offline
17 PSI, ay carumba! I got into it this morning to see what it would do. The most I saw was about 12 PSI but I was hurtling fown the highway so fast I was fearing the steely cold grip of handcuffs.
87 TC, 5 Speed.
duanetc Offline
i have a 87 tc with a 5 speed the guy i bought it from said it was a replacement motor from ford and it had 80000 since the new motor. i blew a head gasket and pulled the head off found it was cracked put a different head back on it and it still pushes 18 psi in 1&2 and 3,4,5 it pushes 15psi w/o a blow off valve and a ihi with 20000 on it.
t3/t4 ball bearing hybrid spearco intercooler. Ported big valve head, 44pph injectors,motorsport cam and roller followers kirban afpr walbro 255lph fuel pump 65mm tb atrp downpipe extrude honed intakes and a ported e6 atr external wastegate greddy bov prolly some stuff I missed too
