How is this for intercooler tubing?
t-bird88 Offline
I was at Lowe's the other day in the electrical section and I noticed some really nice looking 2" conduit. An then I go to thinking as this stuff looks as though it may be just a tiny bit thicker than exhaust pipe like I had planned on running. There are all kinds of different pieces that can be welded together, and with the addition of a couple of rubber reducers, I think that I can get it to work. I just need some input on this before I beg for money from the war dept.
Jim B Big Grin .
Gunmetal Grey 88 TC!!!!
Dave8338 Offline
Will it be large enough id to work? Pressure shouldn't be an issue.
'86 TC: Granatelli adjustible clutch kit, Energy Suspensions, they own me, New KYB's, NOS heater core in the back seat, Chuck Warren Motor Mounts, Wallbro 255, Kirban FPR, New aluminum dual core. The Goal...all I need is the TIME!!
boostaddict Offline
What about looking on Ebay for intercooler plumbing? I found some for 60 bucks, boots and clamps included.
1988 Turbo Coupe, 5 speed, LS diff
1989 F350 4X4, 5 speed, Banks turbo
1978 Bronco, G 4 speed, 400, chopped top (summertime ride)
sbhjr44 Offline
It is thicker than exhaust pipe and they should have 3 inch also.
Stinger dual3"exhaust from dp & cat to magnaflows w/2.5 outlets w/tailpipes.Homemade CAI w/boost at18psi.MM c/c plates and tubular lca/front coilovers with Koni red adjustables all around. Ported/BV head/A237 and bobslog w/a stinger fmic set-up waiting to go on.86 stang gt w/motor and T-5 from a 86 TC w/3"SS dualexhaust w/cc plates and lowered 1.5".With volvo ic installed.
86 XR7 5spd Offline
do you want "thicker" tubing for some reason ?
exhaust pipe does come in varying thicknesses also ..
I was able to piece my IC tubing together using exh pipe from my local mechanics scrap pile - cost Zero
I used 2.25" exh pipe ; if ya clean it good and paint it, looks pretty decent
polished aluminum or SS doesnt add any power Wink
David T
2.5" exhaust w/ cherry bomb
