Red_LX
Dec 2002
Morgantown, WV
I looked around the dash but can't see any fasteners or anything. Any info would be appreciated, my gauges will probably be here monday and I wanna put em in [Image: smile.gif] Thanks!
Garrett Hunt
Moderator, 2.3L & Turbos Forum @ forums.stangnet.com
'90 LX 2.3L hatchback 5 speed
Cold air w/K&N, Accel coil, Accel adjustable fuel pressure regulator, Pacesetter longtube header, battery in hatch, UPR Blu Thunder shifter, dual Flowmaster cat-back w/'00 GT tailpipes, 3.73 gears, TC front swaybar & '99 GT rear bar, SCR subframes, Steeda strut tower brace, Maximum Motorsports 4-point K-brace, 11" brake conversion, GT seats, clear corners, '85/86 taillights, mismatched hood thanks to a deer. Now my beater.
Future mods: Currently unknown.
'87 Thunderbird Turbo Coupe
Cone filter on VAM, Racer Walsh underdrive pulleys (stolen from the stang)
redlx.stangnet.com
Garrett Hunt
Windage tray, crank scraper, P&P head, RR, ARP head studs, P&P intakes, 60mm TB, Accel AFPR, Bob's log, T3, big FMIC, blow-thru VAM, Forge BOV, 3" exhaust, UPR shifter, gauges, etc.
My Turbo Coupe
segfaultxr7
Aug 2001
Cape Coral, FL
The bezel is attached w/ phillips head screws. Follow around the edges, there are a bunch in the gap between it and the center stack, etc. Look around with a flashlight, you'll find 'em. If you need more specific info let me know, I had a few too many tonight so my memory is a little hazy right now. [Image: smile.gif]
88 TC 5-speed
Once you get the whole big trim piece of that goes around the cluster, 2 center A/C and left side A/C vents, it will be obvious how to remove the cluster.
Red_LX
Dec 2002
Morgantown, WV
That big trim piece was the part I was stumped on. Thanks!
Garrett Hunt
redlx.stangnet.com
Garrett Hunt
My Turbo Coupe
You have to remove the trim around the headlight switch and the ride / reg-prem switch to get at the bottom 4 screws. The top /side screws should be easy to spot if you look with a bright light.
