I have this Frankenstein project breathing.
I have hooked a hose from the outlet port on the turbo, (pressure source) to the inlet of the manual boost controller.
Secondly, I hooked a hose from the outlet of the boost controller to the port nearest the exhaust header on a Turbosmart wastegate. One diagram showed the port farthest from the exhaust left open to the atmosphere. Other diagrams showed it differently.
Am a I correct so far?
And at what point should I insert a T fitting that would go to a boost gauge?
Thanks to all.
The pickup with the 85 Turbobird 2.3 in it, runs good until I accelerate quickly and then it pops a bit. Tests showed my throttle position sensor giving way too low voltages. Ordered a new one.
Thanks to all.
