Thndrchckn420
Mar 2003
Winchester, VA
Anyone know what size the hood bolts are? I misplaced mine sometime in the last 9 months while it was apart. Thanks
88 5-spd. Precision SC-50 ball bearing turbo, gillis, full 3" exhaust w/ 3- 1/2 crome tip, ported E-6, ported big exhaust valve head, ranger roller cam, Essy cam gear, K&N cone in front of the radiator, gutted upper, knife edged lower, Walbro 255HP pump, Kirban AFPR, Forge BPV, PA Performance 130 AMP Alt...
Thndrchckn420
Mar 2003
Winchester, VA
Bump... It IS hood not head. The bolts that hold the hood to the hinges. Anyone?
There is a number listed; N606689-S36, 16-25 lb.ft.
It does not give the size
Thndrchckn420
Mar 2003
Winchester, VA
Yeah, I found that. Guess Ill use the old trial and error method. Ill make sure I list it in the part #s section when I find it. Thanks
