hissing noise and code 41
w60 Offline
I feel like a needy nerd asking so many questions. I have a code 41, a hissing noise and a coolant smell below the intercooler.
I can't find anything leaking... and I'm sure I left something un-hooked.
Any ideas?
http://www.mycoachonline.com
White 88 TC Auto Trans
White 04 Honda CR/V
Blue 74 Honda Trail 70
41 = PCM detected a lean condition when closed loop was commanded on. Most common cause is a vacuum leak, as indicated by the hissing noise. Take the IC off and have a look.
Coolant smell is unrelated to the code 41. Check the water lines to the turbo and heater lines that run along the valve cover while you have the IC off. May need to pressurize the cooling system to find the leak.
w60 Offline
Vacuum leak Smile
On the vacuum T, there is a line that branches off and it has a "T" on it, but it's not connected to anything and it isn't plugged. The transmission shifts very hard...so the "T" must be for "Transmission"!
White 04 Honda CR/V
w60 Offline
Another question, is it possible for engine oil to mix with transmission fluid? I'm sure I'm being paranoid, but I added engine oil and I think the transmission oil level went up.
PS I'm not sure because it was months ago that I last checked the transmission oil.
White 04 Honda CR/V
Never the two shall meet. Separated systems. Any chance the first check was with a cold trans and the second check was with the trans warm? Temperature can make some degree of difference in the dipstick reading.
