Sean Story
Apr 2009
Laurel, Delawere
is it just me or is the HIH kinda falls on it face went you get in the higher rpm zone and i am not running high grade gas yet so i dident test the switch for 15 pounds of boost yet does the switch fix that problem???
S.STORY \ 88 TURBO (project 2.3) \ Laurel, Delaware 19956.
turbospoolin23
Jan 2007
Canada,AB
It's an IHI turbo. It's a small turbo and runs out of steam in the higher RPMs regardless where the boost is set.
87 TC 5 spd... 17X9 Cobra R's, .60/.63 SVO T3 Turbo, Large NPR, Manual Boost Controller, AEM Wideband, BPV, K&N Cone, Walbro 255, Kirban AFPR, 3G Alternator Conversion, Short Throw Shifter, Stinger 3" Exhaust, Magnaflow Catalytic Converter & Muffler.
junkedturbo
Apr 2008
Batavia IL
You will get more power though if you flip the switch
Just make sure you put in higher grade gas.
zbird
Jul 2008
Joshua, Texas
I know you can run 17 PSI pretty easy with a gillis and Timing to 12-14 deg. Just run 93 octane and keep the switch in premium and you can get more HP out of that little IHI turbo. Just make sure everything is in tip top running order before you go messin around for more HP. Also be sure to listen for detonation (ping/knock) because every engine is not in the same condition. If you hear it back of a little on the boost or adjust timing accordingly.
