JohnathanB
Jan 2013
thomasville NC
Does a high volume oil pump fit in are motors? I recently rebuilt my motor again!!! I got a crank from a fellow member and my oil pump craped on me right from the start...and I put a high volume pump on it now my motor won't start? I checked clearances between the pan and crank on a old 2.3 block it cleared by a good bit but I didn't have rods in it but it was only taller at the base and I reused my old pickup now my motor won't turn over? I also need a new clutch disk I'm pretty sure it's to the metal on the flywheel side but idk which one will cause it a rod not clearing the oil pump or the flywheel rusted the clutch disk
88tc 5spd new paint, cobra r rims, mods are :header back exhaust 3inc to 2.5 duals, jdm t3/t4 stage 3 turbo 20psi,jdm external wastegate, k&n filter on vam, fmic, new bottom end .422 lift cam, c4 trans being built
Not B Anymore
Nokesville, VA, USA
Yes - a high volume pump does fit, but it is strongly advised not to use one due to the fact that it puts more stress on an already weak link in the system and can accelerate or cause the failure of the dizzy/aux. shaft gears and/or pump drive.
86XR7auto
Mar 2003
Mt. Pleasant, MI. USA
What Brian said...
Unless you have plans to build a 8000rpm screamer....if so than by all means...
If you aren't that guy the stock stuff works great...
Travis
JohnathanB
Jan 2013
thomasville NC
Thanks for the advice I now got her running again the transmission was locking her up?
JohnathanB
Jan 2013
thomasville NC
I also found a ball of clutch material that looked like chicken feathers in the bell housing lol I think the clutch is screwd
Matthew88
Aug 2013
Albany, NY
Johnathan it's good to see you got the car running again, but are you still running the high volume oil pump? if so I would heed these guys warnings. Do some searching on here And turboford regarding gear/shaft failure and you will see why.
-Matt
1987 Turbocoupe 5 Speed
JohnathanB
Jan 2013
thomasville NC
Yea its to late I have it in now and everything is ok so far and I'm not going to pull it out yet bc I'm tired of screwing with the car I just want to drive it but if it ever just dies on me I know why
86XR7auto
Mar 2003
Just keep an eye on the dizzy gear...also u will probably blow out some engine seals....sorry. Its just not needed for 99% of 2.3T owners...the stock oiling system is great.
Travis
JohnathanB
Jan 2013
thomasville NC
I'm planning on doing a folvo head conversion motor and I'm going to try and turn it 8.5k atleast I have and hey I already got the pump lol
RC Martin
Mar 2006
Colorado
I've read another reason to consider not getting an HP of HV oil pump is the turbo. The seals and oiling inside the turbo are much smaller and weaker than the engine's, meaning with HP/HV you are more likely to blow oil past the seals or damage it somehow...
