High pitched starter
GlassRooster Offline
Coming home today the car died. When I went to restart the engine (it didnt) the starter made a higher pitch turning noise as opposed to it's normal sound. Being towed any clues about the starter ..Engine was turning over but not firing up. any clues?
David
87 TC Faded Burgundy with faded red interior
K&N and cold air ducting- rest is bone stock
02 Mazda Protege 5 Replaced Dead Saturn
99 Cougar- Wife's car new body style now Discontinued.
Are you positive the engine was actually turning over? not just the starter?
belts were turning.. Alternator goin round and round. Had voltage meter.. battery was 11.45 while cranking and battery was 12.5 while just sittin there..had a buddy in the car with me. He wasnt happy either lol
David
Which belts, accessory drive belts and cam belt or just accessory drive belts? Maybe the cam belt broke or distributor gear stripped. Pull dist cap and see if the rotor turns when cranked.
Mr.T Offline
Pete, I'm w/ you on this one. Sounds just a like a broken timing belt. That's what I'm betting on.
1985 T-bird TC, 5Spd, Black (The Project)
1985 T-bird TC, 5Spd, Black (The Project II)
1986 T-bird TC, 5Spd, Black (The Show Car)
1986 T-bird TC, 5Spd, Silver (The Daily Driver)
1988 Mustang GT, 5Spd, Black (T-Top)
1989 Mustang GT, 5Spd, Black (Sunroof)
1986 T-bird TC, 5Spd, Black (The Project Car)
only two belts I know about .. the A/C belt and the one around the water pump and the alternator and P/s pump.. but will do and let u know ...tomorrow thanks
David
Ohhhhhh the timing belt ..duh.. ok will let you know.
David
Servey says...Number 1 answer...the timing belt was shredded wheat. Got it back together PITA runs like a top.. Woo Hoo...I wont forget that sound again. Can you upload a recorded engine noise for diagnostic purposes to the message board?? It would be a .WAV file.
David
If you change the belt every 60K as recommended you will never have to hear that sound again!! [Image: biggrin.gif]
