High Idle Some Times
oldturboman Offline
My 88 TC Stock Automatic idles between 1800-2100 at times when at normal operating temp.Have cleaned IAB also installed one of those F2PZ-9F939-A Idle Air Adjust Spacers from Ford on it,idles fine sometimes fast others. Example- Drove to MD 75 miles idled fast 2100 drove home 75 miles idled 1000 both times in park,doesn't seem to do this cold just after warm-up.Doesn't matter if you run it hard or not.Any ideas anyone? By the way the idle plate discussed earlier in week by someone is still avilable from Ford kit cost me $16.69+ tax.You can still get copy of TSB 91-25-7 if you ask them for it. THX Oldturboman
1987&1988 Turbo T-Birds
1-1987 Auto 1-1987 5sp. Both Turbo T-Birds NATO Member
Do you have your base idle speed and TPS voltage set properly? Check out the article in the tech section for info on how to set these.
Kev Offline
If you don't have any vacuum leaks then I would say definately TPS. It is either bad or needs to be adjusted. Mine did the same thing and just needed to be adjusted.
Kev
Kev
1988 TC 5spd
BJL Offline
Moderator
my car does that if i dotn warm it up in the mornign for more then 15mins, annoyign when its a 5spd, cuz you go to give it the same amount of ggas as you woud when its at 1000, and you end up spinnign the wheels.
i thinks it my tps, but my car is int eh shop now so i cant mess with it.
OLDTURBOMAN:
By The Way , hows the riveshaft doing?
get the BAS Sensors fixed??
Brian J Larkin
18 yr old male totally loves his tbird, Smile
1988 Turbo Coupe 5spd, dark blue
http://crazydriver358.5u.com
Brian J Larkin
88TC 328,000 miles
89 Cougar XR7 3.8SC Auto
95 Ranger Splash 3.0 auto
oldturboman Offline
Thanks,Going to set TPS runs and idles to smooth to be vac leak.I should have thought of this but must have been in brain frezze mode.THX oldturboman
