Help with ABS relay diagnosis, please!
evintho Offline
Just got it and already asking for help! I ran the ABS relay diagnosis from the FAQ's. I jumpered the T/Y & GY/R terminals and the pump motor ran with the key both OFF and in the RUN psition.
Put the relay back in, turned the key to ON and pressed the pedal several times, the motor didn't run.
Probed the PK/LB wire and with the key ON grounded the wire - pump motor ran.
It was a little different than the FAQ write up but it sounds as if the relay is good. What's next? Pressure switch? If so, is that a Ford only item or can I grab one at NAPA or Autozone?
Proverbs 3:5
Check out Thunderstang!
There are past posts on testing the pressure switch.
http://natomessageboard.com/cgi-bin/ulti...605#000003
http://natomessageboard.com/cgi-bin/ulti...510#000003
See JT here
http://natomessageboard.com/cgi-bin/ulti...866#000007
Could be the press sw. Before spending $150 on a new one, remove the connector from the pressure switch, and jumper the PK/LB wire terminal to the ground terminal of the press sw. I forget the color of the ground, but you can locate it with a DMM easily. If jumping those 2 pins at the press sw gets the motor to run, the problem sounds like the press sw.
evintho Offline
Found the problem! The tiny plastic tang that holds the PK/LB wire into the pressure switch connector broke off, consequently the wire pushed out the back and wasn't making a connection. Put it back in and dabbed a bit of 2-part epoxy in the back of the connector to hold it. Problem solved!
NATO membership - best $20 I ever spent. Just saved me $150 on a pressure switch! Also, found the reason the aux fan was on all the time. PO had it wired directly into the coil! Thanks Pete D! He must've wired it for a reason. Is there any way to test the IRCM?
Proverbs 3:5
Get rid of that aux fan directly wired to the coil right away unless you like burning up the harness. The fan draws lots of current that the coil power circuit was not designed to handle.
2 ways to test IRCM fan circuits: 1) run KOEO test. 2) Disconnect ECT and jumper terminals in ECT connector. Start motor. Both fans should run.
evintho Offline
Yeah, he had it pushed into the back of the connector on the coil. Now the back of the connector's all melted!
I'm gonna try #2 today. So if both fans DON'T run, does that mean the contacts aren't closing in the relay, hence bad relay?
Proverbs 3:5
Pete D2 Offline
If both fans DO run it means the wiring, IRCM, connectors and fan motors ARE OK. If both do not run you need to start checking the above.
Turbo
