Help...strange miss????
JohnathanB Offline
Ok so I got my Tc going again I have fixed the driveshaft from vibe rating,stop the transmission from leaking, hopefully I just fixed the check engine light bc of the o2 sensor but my car has always missed at idle I have tryed changing the pointer/distributer cap , plug wires and plugs but still won't quit ...any advice?
88tc 5spd new paint, cobra r rims, mods are :header back exhaust 3inc to 2.5 duals, jdm t3/t4 stage 3 turbo 20psi,jdm external wastegate, k&n filter on vam, fmic, new bottom end .422 lift cam, c4 trans being built
An 02 code doesn't not always mean the 02 sensor is bad. It can be something else going on. Try pulling the codes and see what you get for each of the 3 phases of code reporting.
http://turbotbird.com/techinfo/Retrievin..._codes.htm
http://turbotbird.com/techinfo/In_Car_Co...rCodes.htm
http://www.tbirdheritage.com/turbocoupe/...-Chart.php
Let us know what codes you get for each phase.
JohnathanB Offline
Well I pulled them b4 and one of them was couldn't read the o2 sensor then I a lot of the other codes kept saying rich/lean so I kinda figured the o2 sensor was causing them all
Think of it as the 02 sensor responding to all the other codes, not causing them. It would help to know the codes, by number, for each part of the test.
JohnathanB Offline
Ok we'll I'm trying to get m hands on another code reader and ill let y'all know something
What do you mean ......"and one of them was couldn't read the o2 sensor"??? There is no such code or codes for that. EEC IV / OBDI does not check for O2 circuit integrity.
JohnathanB Offline
ok sorry it took so long.. but jeff: I ment to say I thought it couldn't read the o2 sensor
but the codes are
12: RPM out of spec...rich condition?
24: ACT out of range
26: MAF(VAF)out of range
42: system always rich
54: ACT (VAT) input to high...maybe caused by code 24?
74: Brake on/off switch ...bad pressure switch but I bypassed it
85: Canister purge (CANP) circuit fault... what is that?
JohnathanB Offline
but the codes are
12-ECA could not increase idle speed above normal idle Suspect throttle body coking.
24-ACT (Air Charge Temperature) sensor voltage out of range. Suspect ACT sensor and harness.
26, The needed spec are in more than 1 old post (VAM or VAF
42 always rich. Check for vacuum leak(s) and/or high fuel pressure
74-BOO Probably set because the brake pedal wasn't push at the required phase of the KOER test
85-is this an automatic trans car or an auto EEC in a manual car??
JohnathanB Offline
85-ok...yea it was a automatic car and it didn't like my mods lol so swap it to a straight drive and im soon going to put a automatic back in it
42-im pretty sure there is no leaks I have a gauge it stays on 20 pounds of vacuum and everything dealing with fuel is stock oem stuff besides the pump which was replaced 3 years ago
24-its probably a bad sensor ive had my motor apart a few times/but could that cause the car to run rich? being that it don't know how to adjust for the weather? for rich and lean conditions?
12- my car does no idle when I first start it up it runs super lean but then it richens out alittle bit as it gets warmer for example I have to hold the car at like 2grand for like 2 mins for it to start idleing from a cold start
