HELP PLEASE!!!
Keith Pellerito Offline
Just wondering if anyone has any good pics, websites or just anything to help properly put the engine back together. I have the Haynes book and we all know how unhelful that is. Any help is appreciated. The main block is back together with the exhaust and intake and turbo mounted up, it is just all of the coolant hoses and oil supply lines and vacuum lines I really need.
yeah it is fast, just a little slow getting back to the garage!🚓
turbocoupes Offline
Post a note to robards...I noticed he's selling a car and has a complete motor to install... pics in the "cars forsale" section..."robards-88tc white"...maybe he'd be nice enough to take more pics of it for ya! worth a shot...
Garry McVey "BIRDS OF A FEATHER" Birdoprey always in flight... TBird TC owners are usually wingin' it
TC's 83 project, 86 donor for 83, 86 FUN street car,87 RIP, 87 blue to be stock street car, 87 red donor for blue and others, 87 red daily driver, 88 street and strip HALF WICKED right now, 87 XR4ti project,80 pinto wgn project
Garry McVey "BIRDS OF A FEATHER" TBird TC owners are usually wingin' it
TC's 83 project, 86 donor for 83, 86 FUN street car daily driver with speed equipment from Red 88 donor, 87 blue to be stock street car, 87 red donor for blue and others, 87 red donor, 88 street and strip(now a donor) 14.01 chasin 13.0's, 87 XR4ti project,
Cooling: http://www.turbotbird.com/FAQpage/cooling1.jpg
Vacuum: http://www.turbotbird.com/FAQpage/Vac_Diagram.htm
B. J. McDuff Offline
Let me try this one, I was in your boots just last week.
1) Water from water pump outlet, via steel tube to input of heater core.
2) From core outlet to steel tube running behind valve cover to oil cooler on lower, D/S of motor.
3) From cooler outlet to steel tubing returning behind valve cover, back to P/S of motor, connecting to a third steel tube leading to water pump suction (inlet).
4) Small, 5/16 in. tube welded on larger 1/2 in. tube, near the oil cooler, is connected via U shape rubber hose to small, centered inlet into bottom of intake manifold. (Water jacket).
5) Small, 5/16 in. tube welded on larger tube, in vicinity of turbo, feeds cooling water to the turbo cartridge.
6) Cartridge cooling water is returned to lower P/S of motor block via small diameter tube and hi-temp hose.
7) Small diameter, steel line(crooked dude) supplies oil from PSI sender fitting located on D/S, rear of motor. It of course connects to the turbo cartridge oil inlet.
8) Oil is drained from turbo via large corrugated SS flex tube directly into a boss located on the P/S of the motor, directly below the turbo.
Rubber hose ells are used in several places to facilitate connections. I fiddled and f--ted with all these pieces and the above is how I remember putting them back. They were taken off an '87 TC several weeks ago. We'll check them tomorrow PM, to make sure of the connections.
Have yet to figure out the vac lines, but hopefully there is a diagram on the underside of your cars hood.
JMcD
see pic
turbocoupes Offline
Yoose guys are the best! [Image: biggrin.gif] [Image: biggrin.gif] ! Your motor Pete? Who's ever it is ...looks well down... [Image: biggrin.gif]
88silver-bullet Offline
Damn Pete, that's an awesome looking motor. did you ceramic coat the exhaust manifold?
Guy
88 silver t.c100,000 just did an engine and t5 swap
Pete, that last pic that you put up, the bottom pipe for the coolant line----where does that on go? Thanks by the way for the helpful links/pics to everyone so far. I am sure I will bug you more.
Keith, Those are the lines as they came off the car back in 2000. What goes where is as much a mystery to me today as it is to you.
88silver-bullet and Turbocoupes: That the motor I built in 2001. The E6 was coated with some stuff called "Hot Stuff" from JC Whiteny. It held up for a couple years.
The bottom pictured configuration of lines connects the heater core, to the oil cooler. See Item no. 2 in above post.
The small, short legged U tube (hose) connects to the center, bottom of the intake maniforld water jacket. See Item no. 4 in above post.
Pete's taken his wify out to dinner. [Image: biggrin.gif]
BJMcD
