Ford4life
May 2017
Roanoke, VA
88 Turbo coupe, can't get the passenger door to unlock with the key or keyless entry, any suggestions? Thanks.
RocketshipChair
Nov 2011
Rochester, NY
If you pull on the interior door handle doesn't it unlock? It sounds like your latch is bound up or jammed. You might be able to bang on the side of the door by the latch with your hand while pushing against the door and operating the interior handle. You can also try removing the sill trim from the window and shine a flashlight down the opening and see if you have anything jammed.
Andrew
88 Turbo Bird 5 spd no mods
Ford4life
May 2017
Roanoke, VA
The lock actuator was stuck in the locked position. Had to sit in the driver seat and take the door panel off from inside the car, what a pain in the butt. Once I got to it, i was able to unhook the arm from the electronic actuator and unlock the door with the key. Just don't have power lock on the passenger side but I can live with that temporarily.
