HELP, NO POWER !!
ulost Offline
Ihe car has new plugs & wires, new fuel filter, new cap, new rotor. The car can hardly get out of it's own way. It almost feels like it's not getting enough fuel. I also installed a 255lph fuel pump...
Thanks!
Spooler87 Offline
Hmmm. sounds like what i'm going through. I have a thread i started about my issues, mabey the responses there will help
All hail Project "Marauder" !
ratrapp Offline
did you check to see if the timing belt has jumped?
88 turbo coupe ported e6 kirban afpr forge bpv walbro 255lph stinger3" dp into 2 1/2 duals ultra flows bobs gutted upper with 60mm tb ranger roller cam.t-3 race engineering cam pulley gillis vale k&n cone 3.73s centerforce d/f 140 motorsports speedo and fms rear spoiler 17x9 cobras
Thanks!
We need WAY more info!!!!!!! What diagnostics have you already done? Is the CEL on? HAve you checked fuel pressure under load? Have you checked ignition timing (and cam timing as noted above)? Does it idle well? WHat pressure does it boost to and at what RPM?
Liquid_force Offline
Any tears or lose hose clamps on the vam to turbo inlet hose? tears or loose clamps on the compressor outlet to IC? the ic to throttle body? Might you have switched a couple plug wires?
88 TC -- Dark Blue 283k
RIP - 9/22/07
ulost Offline
The only code it had in it was a 42. The fuel pressure at idle is 39psi and at 18lbs of boost the pressure is 65 to 67psi. Ignition timing is 10 degrees with the spout connector removed. I have checked everything that I know of except the timing belt....
ulost Offline
I forgot to say that I am running NGK TR6 spark plugs gapped @ .035. What do you think?
Just checking, did you put the spout back in? Is the spout making good contact?
ulost Offline
Spout is connected, there was a bit of build up inside the spout terminals. I checked to see if the timing was advancing by putting the light on it when I connected the spout, all looks well in that area. Someone said something about having a couple of plug wires crossed, would the car have a dead misfire if this was true? The firing order is 1,3,4,2 right? # 1 is at the front of the car right? I am going to check the timing belt today to see if it's lined up right.
Joe F Offline
1-3-4-2, correct. 1 in front, also correct.
Have you checked for a plugged cat?
