ES TC NUT
Sep 2001
Three Oaks, MI USA
Need some help guys. Last night the TC was sitting in the driveway idling and both headlights went out. Took both bulbs and hooked them up to wifes Taurus and they work. I also made sure the delay was shut off on the autolamps. Any ideas? I hate electrical problems.
segfaultxr7
Aug 2001
Cape Coral, FL
Check the fuses, I *think* there's also a headlamp circuit breaker but I'm not sure where that would be. Also try jiggling an pressing your headlight and highbeam switches. If they come back on when you do that, replace the switch even if it seems to work fine afterwards. Or, if you know someone who's good with electrical stuff, have them try taking cleaning the contacts.
88 TC 5-speed
Mr. Sam Ford
Richmond, VA
Check to see if the high beams work. If only the highs work it very well could be your flash to pass/high-low switch on the column. Been there, done that
'88 Thunderbird TC, daily headache with a few mods, 14.65 and still not happy
'86 Mustang GT, daily transport, fresh 302, Twisted Wedge heads, Track Heat intake, custom cam, all the associated goodies, 4.10s, hoping for mid 12s n/a
methos
May 2001
Cynthiana, KY
I had such a problem in my 90 crown vic, be driving along and all the sudden... poof, no headlights or lights of any sort... as it turned out the curcuit breaker inside the pull switch was going bad and we had to replace that... hope this helps...
Jason Schaffer
88TC - 5speed, all options but leather and sunroof
Mods:
Esslinger Prepped head, AiResearch T-3, 3.73 gears, Schneider custom grind cam, chromed rims, dynomax on the duals, and last but not least... new interior
AIM - Shizniblit
Jason Schaffer
Mods: 3.73 Gears
Finally getting it back together.
