I'm a new guy looking for a little help.
I finally shipped my Cougar out here to me in Vegas and have been working on cleaning it up and finishing up some little things. A little bit of background on the car... The car is an 86 Cougar that originally had a 5.0/AOD. I bought a wrecked 86 XR7 and swapped over the 2.3T engine and C3 tranny. All of the car's original wiring was removed and all of the XR7's wiring was used for the swap. The car was running fine up until today...
I turned on the marker lights and noticed a few bulbs were burned out. I pulled the cluster out and replaced them but when I turned the lights back on, the lights did not come on and the fuel pump came on. If I crank the car the dash lights come on when cranking, but when not cranking the High beam indicator and both turn signal indicators light up. No other changes were made, only light bulbs changed. I pulled the cluster back out and the fuel pump stopped priming with the headlight switch, but plugging it back in caused the same effect again. I pulled the dash out thinking maybe a wire was pinched but had the same results. Then the pump started to prime even without the cluster connected, so I am stumped. I applied 12v to the various pins in the cluster plug and pin #1 and pin #16 made the pump prime. Now according to the pinouts on Coolcats, pin 1 is for "Brake, turbo, tach & speedo 12V+" and pin 16 is for "Tach in."
I would really like to get this stuff sorted out because I did the engine swap 3 years ago and have never driven the car. Thanks in advance!
Ed
Ed
1986 Mercury Cougar - 5.0 delete mod, 2.3T swap.
