shawn024
Oct 2001
kalamazoo,mi.,u.s.
I cant get the keyless entry code cause when they painted the car before i got it all the codes that where on it like the gas cap and under the trunk and hode are gone.Is there any way of getting a code to work please help!!!!!!! thanks shawn024
Wags88TC
Las Vegas
OK, here's an idea find the little sticker on the trunk hinge arm-a rectangle about 1/4"x3/4" and use a little paint remover, rub a little on and wipe off. Be carefull it could eat the #'s as well! [Image: biggrin.gif]
Steve Wagner
Nato member
84 SVO
JT
The number should be stamped on the module itself, located inside the trunk on the left package tray.
JT
JT
[email protected]
www.geocities.com/turbocpe/
1987 T-Bird Turbo Coupe T-5
1994 T-Bird LX 4.6L
1988 T-Bird Turbo Coupe A4LD
1988 T-Bird 3.8L
1979 T-Bird Heritage 351M
