Heater Core AZ doesn't fit
T-BirdX3 Offline
I just returned an Auto Zone heater core because it does not fit. It is made out of aluminum, yes aluminum, the center core is very thin not much more than 1/2 inch thick with an insulation pad that runs around the outside of it. All of that is ok I guess but the main thing is the tubes coming out are not bent correctly they come out to straight. So the insulation between the heater box and the firewall doesn't sit correctly. Also the bent tube rubs the heater box. Hope this helps someone the part # is 398010 and it is a Ready-Air unit. I can post pictures if needed.
'88 T-Coupe 5 speed/'88 T-Coupe Auto
'87 T-Coupe 5 speed/'87 T-coupe 5 speed(76k orig mile)
..... and there was light!
http://i1224.photobucket.com/albums/ee36...tled-2.jpg
