UglyBird85
Jan 2009
Norfolk, Va
just in case you were all wondering, a ford heater core is now 114 dollars at the ford dealership. guess this will be a summer only car. I called only 4 months ago and they were $79!!
---Justin
87 Burgundy TC 5spd. K&N Cone filter-Walboro 255HP-.60/.63 Garret T3-Gillis @ 18psi.
SHELF: NPR FMIC-Ford Racing 42# injectors-Tripminder-
Rod K
Dec 2003
Charlotte, NC, US
I put a Ford core in my TC. It lasted 10 months.
My NAPA core has lasted two years and counting.
Rod Kiser, '88TC, 5 speed, 5 lug, Cobra 13" front brakes, Mark VII 11 1/4" rear disc brakes, PiMP'n, Bullit wheels, ATR 3" exhaust, Aluminum driveshaft, EDIS, 60 LB injectors, gutted upper & ported lower. NATO Member
Rod K
Dec 2003
Charlotte, NC, US
LoL. Wow, are they plated with gold now?
goldwing
Aug 2009
North Carolina
No how to's on installation ? I'm don't like the cold. Burr
Why don't some company make a stainless steel one with aluminum fins? I hate having to replace cores.
T.C:87 5 speed
UglyBird85
Jan 2009
Norfolk, Va
Look in the Tech Article, bottom right, under heating and cooling
---Justin
forditude
Dec 2007
Austin, TX
Quote:just in case you were all wondering, a ford heater core is now 114 dollars at the ford dealership. guess this will be a summer only car. I called only 4 months ago and they were $79!!
Then don't buy one from the Ford dealer.
http://www.latemodelrestoration.com/Prod...le=Mustang
Is our heater core the same as the 79-93 mustang with AC? I guess it is, i just never realized that. Is the aluminum better than the OEM? I agree it would be nice to see a SS one. I would like to only do this once...
-88 TC Black
-97 Pathfinder
Yes, the TC and FOX 3 Mustangs use the same core. Thats why it is still available from Ford dealers. If it was a TC specific part, it would have been obsoleted 10+ years ago.
Yeah good point Jeff, i was thinking that as i wrote just didn't know that for a fact. Thanks!
Off point, but from what about an electric heater core... be cool to have it electric until it was hot
random search...
http://www.diyelectriccar.com/forums/sho...44770.html
-88 TC Black
-97 Pathfinder
