Heater - AC blower relay?
TCorBUST Offline
On to the next problem....
My blower for the AC/Heater has recently started to work only in the high position. In my past experience with GM cars that's just a easy to get to relay. You can change them faster than filing up the gas tank.
Is this true for a Tbird? Where is it? If that isn't the problem, does anyone know right away what it might be?
Thanks.
'88 TC 5sp, K&N cone, t3.60/.63, ported head, Felpro 1035, Walbro 255 hi pres., Kirban FPR., 3g Alternator
Assuming you have the manual system:
The EVTM suggest that the thermal limiter for the blower motor is open or the blower motor resistor is open or the blower motor switch is faulty.
I'll try to scan a couple pages from the EVTM later and e-mail them.
You only need two tools in life; WD-40 and Duct tape. If it doesn't move and it should use WD-40. If it moves and it shouldn't, use Duct Tape.
Bigamy is having one wife /husband too many. Monogamy is the same.
[This message has been edited by Pete D (edited 12-23-2003).]
Ford doesnt use a high speed fan relay like some GMs. If fan only works on high, 99.9% chance the blower resistor assy. is toast. It is located on the air plenum, pass side. Has a 3 or 4 wire connector on it. Held in with 2 screws.
TCorBUST Offline
Yes, I remember seeing that when I did the heater core. I'll check the plug connections.
Thanks.
