headliner install
RDOG Offline
How do you get the headliner into the car? Do I have to remove the seats to get it into the car or just lower them? Whats a good technique?
Ballman Offline
when i did mine the 1/4 glass was out and made it easy to go in , go in with it in long ways and have another person on the other side to hold it up and slowly turn the whole thing to fit inside the car, now a moonroof headliner is even harder, you do not want to bend or put a crease in it . seats are better out , as mine were out also, should have some holes in the top rear roof that holds the headliner up . plastic button type interior trim piece, make sure you have the holes are ready in your headliner , dont want to take the headliner in and out to do this job, more chance of getting it bent, after that , or if that happens . KICK your self in the *** . good luck on the job. hope this one is not a moonroof type. D. Wilder
DW
