dlphnfn
Jun 2002
Central Iowa
Question for the electrical gurus...
My headlights went out Saturday night for about 15 seconds, then on for about the same, then off, and etc.
I can have my brights on and it does the same thing.
One thing I did to totally avoid pissing people off was to turn my headlights off (parking lights on) and "flash to pass" all the way home (mostly interstate). (I'm sure that may have pissed off some people too, but it may be better than flashing!)
Question is, do I need the whole new switch? I've searched, and some just bypassed it, but don't have brights anymore. I am looking to get it back to having both "normal".
Any help appreicated.
Erick --
88 Turbo Coupe - K&N Cone, but other than that, completely stock and love it!
2001 Cougar - Wife's car.
2000 Contour SVT - My new car.
2001 Explorer - Wife's.
ILoveMyTC
May 2001
Delaware, Oh.
Mine did the same thing...I replaced the main headlight switch on the dash and it's worked fine ever since.
Nick Johnson
87'TC
88'TC- Distributor gear sitting in the oil pan in pieces
"Educating Columbus, Ohio about the Turbocoupe; One stoplight at a time"
Nick Johnson
88'TC
97'LX
dlphnfn
Jun 2002
Central Iowa
Awesome. Thanks Nick.
Anyone have some sort of drawing or diagram for wiring up aftermarket fog lights. All the older posts' pics are gone by now. I just need to wire up a relay, but I'm clearly not an elecrician.
Thanks,
Erick --
Check the FAQ page for the fog light rewire.
A new light switch will cure your flashing headlight problem.
dlphnfn
Jun 2002
Central Iowa
exactly what I was looking for. Thanks Guys.
Erick --
Liquid_force
Aug 2001
Lawrence, KS USA
Quote:Originally posted by Jeff K:
A new light switch will cure your flashing headlight problem...
it will assuming the used switch you find isn't worn out too. The other alternative is to wire a relay between the dash switch and the lights. I did this for my dims and foglights and it works like a charm.
88 TC -- Dark Blue 283k
RIP - 9/22/07
She was a great TC and went down swinging
dlphnfn
Jun 2002
Central Iowa
Liquid,
I may need more info on that approach. I just called, and Ford wants $133 for a new one.
I don't think it will prove valuable to get one from the JY.
Erick --
1987tc
Bicknell Indiana USA
Niehoff Ignition
Headlight Switch FF3626 $54.99
at www.advanceautoparts.com
Wes
dlphnfn
Jun 2002
Central Iowa
Wes,
Do you have this one, or is it just an offering? I'd like to know if anyone has tried this one? If not, I guess I'll be the newbie!
kibstone
Coatesville, PA USA
Don't forget - you may also need to replace the dimmer switch as well - I tried to get away with just the dash switch for my headlights, but that did not solve the problem. I also had to replace the high/low beam dimmer switch.
My $0.02
Keith
88 TC, mostly stock. Future plans include: Eibach Front Lowering Kit; Gillis Valve; 2.5" Stainless Cat-Back Exhaust (done); T3 turbo; Ported/Polished head work; port-matching on all pieces; and the list could go on and on and on...
