Headlights blinking out
Mjrs_88_TC Offline
Coming home from work this AM, Im crusing, and poof the head lites blink off then on, the brites were on for about 5 miles. I shut the brites down and still the headlites blinked once or twice more.
Not good coming home at 4AM
Im aware about the fog lite wiring problem, with the headlites, but I havent turned on the fogs, until I get a chance to do the mod that it wont drain too much.
Any and all help is appreciated!!!! [Image: confused.gif]
'88 TC, Black, 153K
Coming Soon - K&N filters, Gillis Valve, and who knows what else....
Accomplished - Nuffin yet!
'88 TC, 5spd, Black, Raven Interior,175K, K&N filter, RUNNING like CRAP
Marks \'88 TC in the show room
Accomplished - Nuffin lately!!!
Weak circuit breaker in the light switch. The self reseting CB inside the light sw. gets weak over time, and trips out at too low a current. A new light switch should cure the problem.
Mjrs_88_TC Offline
Ok where would I find a switch? It is still a dealer item or ponder the JY?!?!
mustangtyy Offline
New light switch it what you need. When mine went I got one from a local junk yard for $10.
87 TC with 190,000. Gillis valve, K&N on VAM, Home made "Ram" air, Sac Mustang DP to a 3" Dyno Max Super Turbo dumped before rear axle, Ported E6, Paxton AFPR, GN FMIC, RR Cam, T3 at 20 psi, OBX BOV, Spec Stage III Clutch.
I think the switches are still available new from Ford (since they arent TC specific parts), but I seem to rememberthey cost big $$, like around $80.
MartyPA Offline
Also check to see if you blew a fuse.Mine blinked too and I just put in a bigger fuse and no probs since.
First, the headlight circuit doesnt use a fuse, just the internal circuit breaker in the light switch, so I dont know what fuse you switched out.
Second, putting a larger than original fuse in ANY circuit.... car, house, boat, go-cart, etc, is A BAAAAD IDEA!!!!! Fuses are sized to the gauge of wire in the circuit. Puting in a higher amp fuse is asking for melted wiring and possible a fire. NEVER DO IT!!!!!
Jims88TC Offline
It is definitely the headlight switch as somebody said earlier. I had the same exact problem...except the first time it happened was in front of a cop....so yea I got pulled over. Thank god the cop was a cool guy and let me off. But my mechanic said it was the switch b/c the Ford engineers werent too smart. He said that the switch is supplied more voltage than it can handle...and that causes the switch to heat up and short out. Eventually you may have to replace it again. I replaced the switch instead of taking the other root(rewiring my car).
James
FlyByeBoy Offline
It's the switch dude. I had the same thing 2 months ago. Changed it with a JY switch and it's fine. The switch actually goes bad from the load of the fog lights. If you get a jy switch get it from a non turbo car T-Bird or Cougar one without fogs. Then you know it's going to work.
88 TC X 2 One stock one not so stock. (NATO Member)
Not So Stock 88 TC. 94 SHO w/5speed. (NATO Member)
Mjrs_88_TC Offline
Is replaciing the switch going to help the fog lite blink problem?!?!? Or is it just a fix for the headlites?!?! [Image: confused.gif]
'88 TC, Black, 153K
