Headlights and Glue
pewd88tc Offline
well my Headlight Lens came off the other night i was wondering if there was any glue i could use to secure it till i can get a new headlight ass.. any help is appriciated the cops around here like to target the pedidles... lol
CEO/President Phoenix Edge Nework
Founder Phoenix Edge Web Development
Founder Confused Development
Owner 88' White Tbird TC
1967 Chevy Stepside C-10
366 Smallblock Twin Turbocharged
T5 or T56 Trans (trying to get one)
3.73:1 Rear Gear
822HP @ Crank Dyno 03/01/2006
Dan E Offline
A two-part epoxy should work OK.
Dan Eaves
Dan Eaves
pewd88tc Offline
Any Idea for Lens cleaner or...
and
What new Headlight bulbs should i use
3.73:1 Rear Gear
Megulairs step 2 and a buffing wheel work great. Just don't burn the plastic - keep the wheel moving. It will work by hand but takes longer.
kibstone Offline
Been there, done that. I used a two-part epoxy on my inner marker lights, and it worked great. Make sure you do not fill in the little "weep" holes near the bottom or you could have a condensation problem inside the lens.
I have used a plastic polish and scratch remover with my dremel and a small buffing wheel and it worked great.
My $0.02.
Keith
88 TC, mostly stock. Future plans include: Eibach Front Lowering Kit; Gillis Valve; 2.5" Stainless Cat-Back Exhaust (done); T3 turbo; Ported/Polished head work; port-matching on all pieces; and the list could go on and on and on...
I always use silicone RTV to glue stuff like that together.
Turbojet Offline
My son used JB Weld on his 86' SVO headlight lens.
The Family:
86
87
88
ashleyroachclip Offline
I second the RTV solution , be sure to use clear or translucent tho as you will see any other color once assembled. Ashley
clowns to the left of me , jokers to the right
firsthero Offline
hey. your best bet is to go to your local ford dealer and buy new headlights. as a matter of fact all the front lights are still available from ford. and at a reasonable price.
i understand about the svo lights and its too bad.
bob tweedy
northwest region director
svo owners assoc
86 straight run svo
86 comp prep svo
88 turbo coupe
78 king cobra
69 mercury cyclone 428
1926 model T doctors coupe
segfaultxr7 Offline
I used a clear silicone adhesive for mine, it holds up great plus it can be cut to get the lens back off if necessary, unlike epoxy.
88 TC 5-speed
