Headlights
xcrunnerbd Offline
I know that cleaning/polishing the headlight lenses is not a permanent fix, but wow did it work well on mine. They were not as bad as I thought. I'm wondering though what to use on the reflective surface. Mine is pitted and corroded. I used duplicolor's chrome on a corner lense but it ended up looking like buffed aluminum, not the reflective silver I'd like in a headlight. Now that the lenses are clean I'd like to resurface the inside (you can see the discoloration through the lense).
Shelf: .48 T3, ported E6, BPV
I don't think? I have heard of a good way to refinish the reflector surface.
bhazard Offline
And that is???
xcrunnerbd Offline
We'll see how it turns out, but from the craft section in Meijer (I'm sure Walmart would have it too) I found some silver paint for mirrors. It is drying now and looks like it will be better than how it was but it won't be a "perfect" surface.
Pete D3 Offline
Post some pics if you can.
x
xcrunnerbd Offline
Ok they are all dry now and look much improved. They were pretty bad before I started. The reflective surface now is not mirror like, but I don't have the pits and discoloration I had before. I used Krylon silver metallic found in the craft section of a Meijer store. Its a small spray bottle 8 oz. They won't be like new headlights but look like they will be much better than before, especially with the polished lenses. I didn't take any before pictures (camera had dead battery and I wanted to get started).
Here's what they look like now:
http://natomessageboard.com/uploads/0000...0_0941.jpg
bhazard Offline
I wonder how well that could be polished.
nohandle Offline
check out www.headlightwarehouse.com new headlights at about $90 each. WELL worth the money
87 TC that is very STOCK yet will melt the pavement.....
xcrunnerbd Offline
I gave them several coats and almost duplicated the mirror finish. That pic above was after first coat.
As good as new? Not quite. Better than before? Most definately. Cost - approx. $10. for sandpaper, paint, and plastic polish.
