HeadLights!!!!!
Noname
Guest
My Headlight went out last night.
I want Brighter lights there dimm as hell. My lenses i am gonna clean & Drill a hole in the bottom of them for moisture in them which have just waiting on warmer weather.
But What about xexon bulbs or something like that. Need Some ADVICE!!!!!
16 psi, k&n, gillis valve, 255walbro, kirban reg., a4ld, gauge pod with oil press. and boost gauge.
[This message has been edited by Butterbeanjr (edited 02-18-2003).]
DO NOT put higher wattage bulbs in unless you rewire the system with a relay to carry the load instead of the light switch. If you dont do that, you WILL burn out the light switch sooner or later (probably sooner), and possibly melt the barely good enough for the stock wattage bulbs wiring.
1987tc Offline
A bulb I have had xlnt results with is the Sylvania Extra Vison bulb. 9004XV same wattage as stock but a better bulb that is brighter by a good margin.
Wes
