Headlight switch fix ???
Wags88TC Offline
Suddenly I gotta get the headlight switch just right(between parking lights on & headlights on) to have them both on! From off position, first click(middle)nothing on. Second click(top) headlights on, but no dash or parking lights. Move it back down a little - get it just right and I get everything. I put in the 'parts car' switch, same thing - 2 JY switches, same thing! I took a couple of the switches apart and the contacts are just a bit worn, but I guess enough to have to buy a new switch(I guess I'll leave it on 'auto' from now on).
Steve Wagner
Nato member
84 SVO
http://natoubb.turboford.org/Forum1/HTML/005191.html
Wags88TC Offline
Thanks Pete !!!(guess I shoulda' thought of doing a search)I did look through the FAQ & Tech Articles though - maybe it should be added to the FAQ?
I checked the forward left 15A fuse - it was blown! replaced it (all I had was a 20A)and it works; 1st click parking lights, dash lights, door chime(forgot about that) all work. 2nd click, headlights come on and all of the above stay on, EXCELLENT :d What was killin' me was I took a known good switch out of my other TC; switched 'em and my "bad" switch worked in the other car, but the "good" one still didn't work in mine!
A side note; I tied in my pillar mount A/F and boost gauge lighting to this circuit over a year ago, so I don't really think it's related???
Thanks again. ps Are you just a brainiac and remember all these posts? [Image: wink.gif]
Steve Wagner
Nato member
84 SVO
