Headlight restore
BLKBRD Offline
When i bought my Bird the headlights lens would get water condensation on the inside showing that there is a failed seal around the lens.
After putting up with this for a few years I finally did something about it.
In the past i would just pull out the bulb and use my heat gun to dry out the inside of the light housing.
This past weekend i pulled the lights and fixed the problem.
First removed the light housing from the car and I stuffed the bulb opening with a shop rag and put my air gun into it and gave a quick blast of air to it.
I was trying to be gentle with the air trying not to blow up the whole thing, but the force of the air came too quick.
This turned out to be a blessing!
It popped the lens loose at the spot where the seal had failed around the bottom of the lens which showed me where to start.
I then took my pocket knife and carefully cut and pried off the lens.
I repeated this on the second light housing.
After getting both lens`s off I took my plastic polish to both sides of the lens.
I used my electric buffing wheel on the outside of the lens to bring back the shine.
WARNING: be extra careful not to over heat the lens!
I then took some non-grit plastic polish to the chrome finish on the inside of the housing.
Again, be extra careful not to over polish the chrome.
After they were all cleaned up I washed them in the kitchen sink with dish soap using a soft sponge and then used the air gun to dry them.
Then glue the lens back on the housing with a clear silicon sealer to seal the lens.
I think this will give me a few years of water free headlights!!!
`88 Turbo Coupe Blk/Raven 5 spd
`71 Blazer slammed
`62 Impala SS 409/425
`60 Rambler American SW
`56 F-100, sold
--- several HD`s ---
FLSTCI71 Offline
Good description. In addition to water free operation, clear lights make a huge difference in the looks of the car too. Enjoy your "new" TC!
1987 Turbo Coupe - Son's car
1987 Super Coupe - Son's project car
1934 Ford - My project car
Blue Oval Bird Offline
Just had one pop out at 115 - ish MPH over the weekend. Found it this morning at the car wash Sad
1988 Turbo Coupe: 5-speed, 75k original one owner garage kept miles.
MODS: K&N filter on the VAM, Gillis Boost Valve @ 16 PSI, Walbro 255 lph pump, Kirban AFPR, Full STINGER 3" turbo back exhaust with Magnaflow muffler, Motorsports 140 MPH Speedometer.
T-BirdX3 Offline
My problems tends to be the lack of chrome. I have painted a set, looked better but the lighting was no better.
'88 T-Coupe 5 speed/'88 T-Coupe Auto
'87 T-Coupe 5 speed/'87 T-coupe 5 speed(76k orig mile)
..... and there was light!
http://i1224.photobucket.com/albums/ee36...tled-2.jpg
xcrunnerbd Offline
the best stuff I have found for painting the inside of headlights is from a craft store's antique mirror restoration area: Silver mirror restoration paint. It isn't a perfect match to the factory light but is good enough that I will receive "brights" if I leave my brights on. I used to drive with my brights on all the time prior to this and still struggled a bit to see at times.
Shelf: .48 T3, ported E6, BPV
