Sterling
Nov 2011
Wylie, Texas
so i have been having issues with my headlamp switch not working when it is in the on position or running light position, if i turn it inbetween the of and running the running light work. same with the on position and the running light position. could it be the headlamp switch or is it the voltage reg in the back of the gauges? or could it be part of the problem with the IRCM i am having, cause it all happened at the same time. buzzer behind the dash, headlamp switch malfunctioning, and no fuel pump.
88TC with cold air intake, 255 walborough fuel pump, upgraded fuel pressure reg. 4 core alum rad. gillis valve, upgrades brake system. lightened flywheel and ford racing clutch.
IRCM and the IVR (instrument voltage regulator on back of the cluster have absolutely nothing to do with the headlight switch or circuits. Sounds like the headlight switch is bad.
It sounds like you have a ground problem causing the buzzing relays.
Sterling
Nov 2011
Wylie, Texas
ok so i have checked the switch and connector and they are fine nor burnt wires or connector. so i asume that the headlight switch is bad and needs to be replaced. now the question is where to get one i have looked and cant find one anywhere. now what?
zbird
Jul 2008
Joshua, Texas
You can ask the members who happen to have parts cars if they have a good one. Put it in the want to buy section.
mike schrijvers
Jan 2011
morinville ,alberta,canada
Sterling. I have a parts car. I haven't checked the switch but I assume it is ok. If you give me an address I could send it to you if you pay the shipping.
1988 TC ,silver,5speed,
1988 TC,silver, 5speed,
1988 TC,black,automatic,
1988 TC ,midnight blue, 5 speed
1988 TC,burgandy, 5speed,
1967 mercury cyclone
1974 charger
1988 TC,red,automatic,521 stroker,1,000 miles
1965 parisienne convertable, red ,automatic,140,000 miles
1970 thunderbird 2door fastback,red ,automatic,76,000 miles
1999 dodge viper RT,black,44,000 miles
2001 plymouth prowler,blue, 8,000 miles
2006 SSR ,yellow, automatic, 26,000 miles
