Headers With A/C?
DaleLeo Offline
Hi
Has anyone added headers and kept thier A/C operative?
If so, Vendor P/N would be most appreciated.
I've only seen headers non compatible with A/C and I'm looking for alteratives.
Thanks you!
Dale
spittinfire Offline
The closest thing that I know of still in current production is the Gnari manifold. I believe it has addressed some of the cracking issues but I don't know how much more it flows over a stock manifold.
DaleLeo likes this post
BradM Offline
Gnari does work with AC. It's not a header and I recall seeing some testing that showed Gnari flows better than OEM. It's certainly bigger and you can look through the turbo flange straight to the #3 port. You can't do that with OEM.
DaleLeo Offline
(08-01-2022, 12:13 PM)spittinfire Wrote: The closest thing that I know of still in current production is the Gnari manifold.  I believe it has addressed some of the cracking issues but I don't know how much more it flows over a stock manifold.
Thank you very much!  This information was very helpful
DaleLeo Offline
(08-02-2022, 09:56 PM)BradM Wrote: Gnari does work with AC. It's not a header and I recall seeing some testing that showed Gnari flows better than OEM. It's certainly bigger and you can look through the turbo flange straight to the #3 port. You can't do that with OEM.
Brad, Thank You!
Do you have one?  Have you been satisfied?
BradM Offline
I do have one. But I installed it along with a T3/T4 Garrett, 3" DP with dual 2.5" exhaust (FlowMaster FlowFX), FMIC, and PiPMx so you can't tell what kind of improvement you get with it alone. But visually it has much bigger chambers.
Attached Files Image(s)
DaleLeo Offline
(08-03-2022, 01:10 PM)BradM Wrote: I do have one. But I installed it along with a T3/T4 Garrett, 3" DP with dual 2.5" exhaust (FlowMaster FlowFX), FMIC, and PiPMx so you can't tell what kind of improvement you get with it alone. But visually it has much bigger chambers.
Thank you Brad
John B Offline
I also have a gnari manifold on my 88. Same as Brad, it is tough to tell the kind of improvement because I installed it with several other modifications. I did port the manifold a little more to gasket match on the turbo side. Overall, I like the manifold. Haven't had any issues with it over the last 4 years
DaleLeo Offline
(08-03-2022, 07:20 PM)John B Wrote: I also have a gnari manifold on my 88. Same as Brad, it is tough to tell the kind of improvement because I installed it with several other modifications. I did port the manifold a little more to gasket match on the turbo side. Overall, I like the manifold. Haven't had any issues with it over the last 4 years
Thank you John
