nidex
Aug 2002
Waukesha, WI
I know someone who was thinking about getting a 87/88 5.0L Thunderbird. He doesn't like the front grille, and was wondering if he could swap a TC grille on and have it fit perfectly? I was pretty sure you can but would like some extra input. Thanks.
Hybridbird
Aug 2001
Rockford IL
Yes,it is a direct swap.Although the inside marker lights(next to the headlights) are model specific to the car,so make sure the car you get the header panel from you get those 2 lights also.You want to also be sure that the black plastic air dam underneath the car is intact and functional as well to make sure your cooling syatem is functioning properly.I have done this swap to my Sport coupe and it is pretty straight forward.Give a yell if you need some help,good luck.
