head gasket?
slacken00 Offline
i have been smelling anti freeze but cant find a leak anywhere then i just got a new tranny put in and drove it the other day for the first time in a while and smelled anti freeze opened the hood and heard a slight hissing from the exhaust side so i pulled out a flashlight and there is some anti freeze on the side of the block right behind the exhaust manifold and around the back by the firewall, my question is this, does this mean i have a bad seal on the headgasket, or is the head gasket bad, note the head gasket is one of those cometic ones that is steel or metal or something thank you
88 tc black, sc50, stinger 3 inch ex, 255 lph fp, kirban afpr, bov, ported big valve head w/a237 cam, gutted upper intake, (knife edged lower, 75 pph inj. not on yet), spec 3 clutch, street tires best run 13.9, best mph. 109.5(no tuning)
http://s186.photobucket.com/albums/x147/...t=1073.jpg
2008 ford edge sel awd
2000 ford mustang gt,exhaust intake chipped
It could be a head gasket but there is also a coolant line that runs behind the head that could be rusted out. Check close before deciding.
http://natomessageboard.com/uploads/0000...nline1.JPG
slacken00 Offline
yeah im pretty sure its coming from between the head and block, what would you recomend, ps thats a nice engine
Thanks on the engine. I would make sure both the head and the block are flat. When you take the head off, I would measure the breakaway torque of each headbolt just to see if they lost some torque and how much. Might help explain why it's leaking. I like the Felpor HGs but I don't have experience with anything else.
slacken00 Offline
yeah i was thinking about switching to a felpro but im not sure which one id need, any suggestions im pushing about 25-28 lbs. of boost at the track with the sc50 and a couple gallons of 114 octane
