Head Bolts/Gasket other?
deadbird Offline
I tried a search and went through some threads and did not get a definite answer. Mostly because I am not sure what I am looing for.
I am taking the head off and replacing it with one I am having rebuild and worked over. I already found through search that I am going to go with a Felpro 8993 head gasket. Now I am looing at the bolt options.
What should I get. What else should I do with it while I am at it?
1987 5 sp.
- 4.6 2v swap.
boosted chicken Offline
For a mild setup, you can't go wrong with the factory TTY bolts.
88 TC#1 2.9L tall deck. Essy SVO head, Boport header, BW SX369 turbo, C4 trans, MS2xtra
88 TC#2 drag car project(someday)
88 TC#3 parts car (just needed the header panel...bought the whole car, lol)
deadbird Offline
Ok
Is that a good head gasket?
Anything else I should get?
1987 5 sp.
- 4.6 2v swap.
The 8993 is a good gasket and cheaper than the other one. It is more tolerant of minor surface irregularities.
deadbird Offline
Ill do that!
1987 5 sp.
- 4.6 2v swap.
4cammer72 Offline
tty headbolts should never be used on a turbo app.. they were introduced after the end of the turbo motor production and were a cheaper product for ford..used in n/a engines and are a one time use only deal... the 12 point factory bolts on your engine are stronger than arp bolts and they are reusable...6 point bolts now sold as replacements are not suitable for our engines...
Not B Anymore Offline
I've never had a problem running Felpro TTY head bolts on my '86. Yes the factory 12-points would be the way to go if you have them, but I would not hesitate to use TTY bolts on a fairly close to stock setup.
