slacken00
Jun 2001
waynesboro pa
i was getting rid of the cometic head gasket and putting the 1035 on and i was wondering if it is ok to stick with the stock head bolts or get different ones, if so where can i pick them up quick, thank you
88 tc black, sc50, stinger 3 inch ex, 255 lph fp, kirban afpr, bov, ported big valve head w/a237 cam, gutted upper intake, (knife edged lower, 75 pph inj. not on yet), spec 3 clutch, street tires best run 13.9, best mph. 109.5(no tuning)
http://s186.photobucket.com/albums/x147/...t=1073.jpg
2008 ford edge sel awd
2000 ford mustang gt,exhaust intake chipped
slacken00
Jun 2001
waynesboro pa
also i was looking over on turboford and some people were saying they were have a problem with oil leaking out of the manifold bolt holes or something and leaking down around the passenger back side of the block and down the trans. and bell housing area which is exactly what mine is doing but instead of oil its antifreeze, any other ideas i thought it was a leaking head gasket, thank you very much
Sluggo
May 2004
Huntingtown, MD., USA
The exh man bolts go to oil only. A/F could be HG or turbo coolant lines, if you have them, or driping off other coolant lines. Or a freeze plug? I reuse headbolts. TTY or 6 pt up to 3 times has been stated as the max. 12 pt last forever.
Doug
I'm one of those that believes the original 12 point can be reused many times if not abused.
If something is leaking you need to look at whether the bolts lost torque (they can through heat cycling) or something isn't flat, like the head surface AND the block surface. I don't know about the Cometic but I have heard that the 1035 requires very flat surfaces.
CougarXR7
Jun 2006
Marietta, OH
I thought TTY head bolts could be used only once...
1986 Mercury Cougar XR-7
5-Speed - Leather - Dual Manual Seats - Vent Windows - Smokin' T3
AerobirdMotorsports
Dec 2004
Kelso, WA USA
12pts are NOT TTY
6 pts ARE TTY
And yes, TTY bolts can only be used once
