have a question about the car's Knock Sensor.
POWERED BY PSI Offline
Hey guys, just yesterday i realized that when i really jump on the gas..my turbo kicks in great...and it runs great...but once in a while when my turbo kicks in fully to 18-20 PSI, i notice a slight hesitation. Tonight it did it really bad..and i saw my RPMs drop about 2000. then its fine...like i said...sometimes it does it, sometimes it doesnt do it...it seems to do it ALOT worse when the engine is cold..when i first go out in the morning. I disconnected my Knock Sensor...and it is not doing it as bad as it was...so, what is this thats happening...i have checked the usually stuff, everything checks out great..any ideas?
Thanks
Zach
85 Turbocoupe. 5-speed.
Mods- single 2.5 inch exaust with highflow cat and Apex bullit muffler, Saab 9000 front mount IC,Centerforce II clutch kit, Gillis BV set at 19psi,K&N on VAM, Hurst shorthrow shifter.
BEST ET-(1/8)-9.7 @71.9 mph
If your fully boosting a cold engine, I hope your making weekly contributions to a rebuild the engine and turbo fund. If your engine is dropping 2K rpms, something else is wrong. I'm not sure why disconnecting the KS makes it better.
[This message has been edited by Pete D (edited 01-05-2003).]
lol, maybe ill take it easy on those cold mornings from now on! [Image: biggrin.gif] oops! lol, i think my fuel pump isnt enough for this thing. I just replaced it with a stock one...but we all know how the stock Fuel pumps are...anyway,any ideas guys?
Thanks
Zach
Kev Offline
yeah, fuel pump...get a bigger one, make sure IAC is clean and TPS is within range. Tune up, blah, blah, blah, you know the drill.
Kev
1988 TC 5spd
Thanks
Zach
Dont waste time / money on a fuel pump unless you know it isnt up to the task. Measure fuel pressure under boost to be sure it is base (39 psi stock) + boost press at WOT / high RPM, high boost. If the fuel pressure checks out, the pump is OK.
how would i go about checking that? i do have a fuel pressure checker...but is there something i need to do particular? let me know, thanks for all the great help, and keep bustin ass guys!
Zach
Hopefully, your fuel press gauge has a few feet of hose on it so you can tape the gauge to the windshield to see it while driving. If it doesnt have a long enough hose, see if you can modify it with a few feet of HIGH PRESSURE hose so it will reach.
Zach, check your e-mail
