Has anyone tried dying the red stripe on the vinyl?
KentCT88TC Offline
The red stripe on the vinyl strip running around my "new" TC has faded. I want to try to dye it red again. Has anyone here done this successfully, and if so, what did you do? Thanks -Kent
-KentCT
-'88 Turbo Coupe, K&N, Gillis valve @18 lbs., 2.5 " exhaust.
-2000 Mustang GT 373 gears, Diablo computer chip, cold air intake, Typhoon intake manifold.
-2001 Jeep SE 2.5, AEM cold air intake, Gates headers & exhaust, throttle body spacer, Jet Stage 2 chip
I haven't heard of dying per se. I know that people have used colored tape to recover them and some of the ones I have seen look very good. I think that Mike, (AerobirdMotorsports) had some for sale at one time. He posts here and he is listed at the top of the Vendor's page
I painted mine. Has held up quite well for years.
AerobirdMotorsports Offline
Banned
My trim is actual replacement molded red pieces, just like when it was new. It won't help on the rubber moldings in-between the wheels, but all of the other pieces are covered by my kit.
KentCT88TC Offline
Don't know how to do body work like that. But was thinking I could dye that vinyl red again. -Kent
-KentCT
V6TBird87 Offline
What i did, on the faded parts, i wet sanded with 1000 grit sandpaper. Worked like a charm.
2018 Mustang GT
1988 Turbo Coupe, 5-speed
aka Tbird232ci
KentCT88TC Offline
Thanks V6 T-Bird! Will give that a try. -Kent
-KentCT
Ryan H Offline
A buffer with fine paint polish works great also, made the entire trim piece appear to be new on my car.
KentCT88TC Offline
V6T-Bird and Ryan,
Today I used both of your suggestions. Took the 1000 grit sandpaper and wet sanded the entire red molding. It worked-- the red returned, but found it had dulled out both the red and the parts of black molding. Then tried Ryan's idea and used Zaino ZFX Swirl remover and polished it out with an electric polisher. It worked out just great! Did take most of the day. Thanks so much for your suggestions. -Kent
-KentCT
