Guages Not Working
lmp320 Offline
Okay fellas, i have a problem. on my 86, nither the tachoneter or the odometer work. actually, niether does the fuel pick up guage now that i think about it. what could be causing these, esp the odom and tach, i think it is a different problem that the fuel. what could cause them not to work, and what should i do to fix the problem?
Jonesy Offline
The whole gauge cluster is electronic, so it could be a simple case of a bad connection. I would probably take the cluster out and see if the main connector(you will see it, its a big rectangle harness)is plugged in all the way and see if there may be some corrousion on it.
Any other ideas fellas(or ladies)
Jonesy
Michael "Jonesy" Jones
87 Medium Red Clearcoat Metallic 5 speed
2 Tone Leather Interior, All options including factory sunroof/moonroof
168,500 miles - So Far
Mainly stock, K&N Filter, custom ram air
New paint job COMING SOON(repainting factory med. red with ghost flames.)
88thunderchicken Offline
Check the harness Jonesy described for wires that have fallen out. I had crazy guage issues after swapping my dash and thats what did it to me. Also, could this be an IVR problem?
88 Turbocoupe with serious "issues"
lmp320 Offline
so there is no cables i am gonna have to replace? great. what do u mean by electronically done? is it electrically realyed?i will check, if that is what it is, then the local junkyard will have it.
wwwtbirdforumcom Offline
I had that happen on an 88 I had - turned out a fuse was loose- once I pushed it all the wayin those devices started working again. I think it was #14.
Here is my 1987 TC, Mean look - Glad to be here...
[email protected]
Here is a pic of my baby
[Image: Cumberland.gif]
[email protected]
