Cerebral
Jul 2008
Jacksonville, Florida
I had the steering column cover off earlier and i noticed there is a 1 wire Grey plug that someone cut the wire off of. Can anyone tell me where this wire is supposed to go or what it does?
Thanks
1987 Automatic TC- parts car
1987 5 Speed TC, K&N on Vam,Boost controller, T3, Bob's Log, Stinger 3 inch exhaust with Magnaflow, FMIC, Forge Dual Piston B.O.V., Ranger Roller, Esslinger Adjustable Pulley, Boport Drop in Valve Springs, Pyro Pete Clutch
Tom Senior
Feb 2009
Ridgefield CT
I may be wrong about this but i would guess its the key buzzer. I will check on this monday with the factory prints.
Cerebral
Jul 2008
Did you find it Tom???
Tom Senior
Feb 2009
Ridgefield CT
My alldata is down will try again tomorow.
JT
I've got one of the factory Ford wiring diagrams (oversized book - not the troubleshooting manual) and it shows a Gray connector with a Black/Pink wire for the key buzzer. Is the single wire color Black/Pink?
I've found the wiring diagrams to not be 100% accurate, so if you have the wire color and it's different, let us know.
Tom Senior
Feb 2009
Ridgefield CT
All data says its the key buzzer. Hope they are right. YOU can test it by opening the drivers door and use a test light to ground and the buzzer should sound.
