boosted85
Sep 2008
Omaha NE
So i got a complete 85 motor just wanted to know everything that was different compared to the 88 motor, basically whats better for making more power from what i got
Complete custom downpipe to tail pipe 3in exhaust, ranger cam, cran double valve springs, stock dsm bov switchin out for a good aftermarket, cone filter, fmi 2.5in piping, walbro 342hp, aeromotive fpr, fuel pressure 45 base, 17in cobra R's, steel braided oil feed line, 96lb injectors, megasquirt 1 v2.2, msd blaster 2 coil 86 t3 48, innovative lc1 wideband,
Dan S
Jan 2003
Harrisburg, PA
Did you look at the Tech Articles or the FAQ sections, there is a tremendous amount of information there.
Example:
http://www.turbotbird.com/techinfo/Mods/Mods01.htm
As for basic differences '85 vs. '88. Improved electronics and intercooling were the big items. Also, the turbo was changed from the T-3 to an IHI for quicker spool however, the T-3 will make more power.
boosted85
Sep 2008
Omaha NE
so what parts from what motor make more power stock like which head to use which intake which exhaust stuff like that..
Timmay
Nov 2009
Bolivar, Missouri
from wat ive seen the internals are all the same but as for exhaust and intake use the 88 square intake ( might have to drill out one hole but not 100% sure that is if ur using the 85 head)also use the 88 exhaust manifold unless the 85 motor has a e6 manifold on it and if u have the t3 turbo for the 85 motor use it.
jangus
May 2008
Nebraska
Mid year 85 was the change over from the inline intake to the square, and the E3 exhaust to the E6. So first, determine what you've got.
Second, if it's going in your 88, why not just use the 85 long block and swap over all the rest of the 88 parts off your existing engine? IMO, makes things a bit easier.
BTW, being not to far away from your location, where did you score your 85 motor? Found and good TC's or other cars in the u-pull-it?
Haven't been up there in a while.
88TC 5speed, 160,000+, ranger roller, Evergreen T3, cone filter, manual boost controller.
One parts car still waiting to be taken apart.
Waiting in the garage: SC throttle body, SC intercooler, graphic equalizer, among other things.
boosted85
Sep 2008
Omaha NE
no tcs at upull it i caught this one on craigs list so ur saying basically keep the short block and swap my head intake and exhaust on to it o and how to i get the t3 to work its gont a flange on it and i dont know if i should cut it to fit my intercooler piping or what
boosted85
Sep 2008
Omaha NE
o how do u know what it is is there block numbers or something?
jangus
May 2008
Nebraska
Buy a full gasket set, and replace them all on the 85 motor while you've got it out. Only pull the head off if you feel you should check the condition of the bores. And only if you have a new set of headbolts in the budget. Otherwise, don't mess with taking the head off.
Take all the accessories, and intake off the 88 motor and bolt them to the 85 long block. If the 85 motor has the E6 exhaust manifold, leave the T3 on it. You can run the T3 with the flanged outlet if you have an short stubby adapter, which I can fabricate for you if you'd like.
In fact, if you need some guidance and advice, I could drive to up to Omaha this weekend and take a look at what you've got going on. Just let me know via PM. I could also bring up a T3 adapter also. Your other choice would be to find an SVO compressor housing, but the adapter would be cheaper.
boosted85
Sep 2008
Omaha NE
i thought the 88 head was better also there is a e3 manifold on it so im gonna take mine off and put the t3 on to it and on to the motor and i might be interested in the adaptor u have what. do u want for it
