Got a Air/Fuel guage, up-ing fuel pressure help?
BJL Offline
Moderator
well i fianlyl put in the cheapo air/fuel gauge i got form pep-girls. im curious as to see what this non turbo motor does with the turbo computer and injecters.
the car runs liek shit at idle and shakes whiel in drive with foot on brake at a stop light. even tho my friend lauren loves it, it drive me nuts. but when it doesnt shake in dive its runnign kinda rich. all the other tiems it running lean.
crusing down the road it goes from full lean to ideal constantly. never rich.
now first thing when i start it runs ok, but not perfect, is kidna towards the rich side, but after it warms up it goes lean.
now if i dont let the car warm up and try to take off , liek just pull away it stumbles, at this time it goes full elan and then the guages shows nothing, so i put my foot tot hte floor it clear up starts goign and its back to ideal.
my question out of all this rambleing is.
woud;l it be good to try puttign on ym AFPR and bump up the pressure a bit to see if this clear up. or am i taking a risk a destroyign soemthing?
as in the last post i had about this wacky compo mpost think the car owudl run rich while crusiing or accelrating, but its opposite it runs lean, really lean.
thansk for any advice or recomendation on this.
FYI
it has cleaned injectors, new fuel filter, dist. VAM, air filter,from my blue car so ic an see if that was it, also new TPS set at .943 and freshly cleane IAC and i ran an intake system cleaner thorught the vacaum lines when it was running to clear soem shit out. agian thanks!
Brian J Larkin
1988 Non-Turbo Turbo Coupe
med gray met. raven/gray interior, fully loaded minus leather and sunroof!
converted to N/A 2.3l by previuos owner, but its a nice driver with working A/C!
remote start, sequentail turn signals, 2003 stang muff. soon to have 3g alt, stereo, k&n, maybe ported intakes and manifold
1988 Turbo Coupe 5spd
gillis boost valve, k&n cone,AFPR, 255lph, HP pump,3G 130amp alt, 3.73 gears,mild torquie cam, factory DP, 2003 mustang take off SS mufflers and custom BJL 2 1/4 tails.
(needs a front frame pull)
Brian Larkin
88TC 330,000 miles
Slightly Modified
tps87turbo Offline
Brian,
I would put on the Adj Fuel Pressure Regulator & set it to the current seeting that it runs like crap on. Then I would puch it up a few lbs & take it for a spin to see if it helps. Do u know which Fuel Pump is in it?
Tony Sceia
Red 88 TC, Med Red with Raven Leather & every option, Walbro 255, 3" SS Downpipe with Magnaflow Dual SS 2.5 Cat Back system, 3-core Radiator, Star Stage 3 Clutch, Rebuilt T-5 Tranny, 4:10 rear, 140 MPH Speedo, New Paint, Headlights, Refinished Snowflakes & New Tires.
She looks so SWEET. Now I need to make some more HP & make the engine look good.
87 Turbocoupe - Bought as a Parts Car, but runs & needs a little work. Looks like we will have HIS & HERS TC's.
Tony Sceia -
HIS Red 88 TC
BJL Offline
Moderator
the fuel pump that is in it is a slightly loud one that seems aoriganl, i havent put on the fuel line / pump holster yet. so i havetn dropped the tank. but it may be my next move and put the pump in that i took put of my Blue car when i did the 255lph upgrade.
Brian J Larkin
Brian Larkin
88TC 330,000 miles
Slightly Modified
