Ok so my speedo glitches, it's not bad when just idleing but when I use my signals it will glitch a little with the click of the signal, I had to diconnect my wiper switch because whn I try to use the wipers the speedo goes all the way to 80 and back and fourth. The wiper gov makes a wierd noise and sometimes click. The spedo works fine when driving though, please help!
i need radio!
Problem solved, hope no one has to tear it apart as much as I did...
i need radio!
turbobike
Sep 2006
northern Ohio
What was the fix?
85 TC,86 TC,65 Mustang GT
I would like to know how you solved the problem also.
If I were to guess, I would say you replaced the alternator??
Well after ripping the entire dash out(did heater core while I was in the area) I tracked down two relays. One was sticking on and the other wasn't working. There was a ground connecting the two, I spliced into the middle and grounded it to the steering coloumn and everything is perfect now!
i need radio!
